how to configure Different work Hours for each Ext in Queue
KhaledQuenawy
i have Different Queues .. and each Queue have Ext From Different Countries ... so how to specify Work Hours for Each Ext in this Queue
Hello @KhaledQuenawy
How do calls come to each Queue ? If each Queue has a DID, you can use Specific Work Hours in DID Tab
Same DID but i want to specify different Office hours depending on the Ext .. because i have agent in different Countries in the same DID and same Queue
These agents can login/logout from the queue. If logged out (outside of hours), they should not ring when a call is incoming.
If they are in the same queue they should just sign in/out when available. You can use the extension status to auto-logout. I don't recall if you can auto-login as well based on status.
For me the simplest way to do it is to make different working hours/schedule for each extension. And in transfer rules, log off from queue when away or out of office and only log in queue when available.
do you have yealink phones?
we have a proximity script that we use with ifttt (if this than that) app. So when a person arrives at the office it logs them in *30 and when they leave logs them out *31. uses their smartphone. Works pretty well. Can be applied to the queue also.
Using bluetooth?
I have mine set up as geofence, but you can use whatever rules you want, ie connecting to a wifi access point, Bluetooth, etc.
Arrive
https://phone.server.ca/proximity.php?ext=260&dnd=1&pwd=te20hz
Leave
https://phone.server.ca/proximity.php?ext=260&dnd=2&pwd=te20hz
the proximity script on the server has this as part of the code
if($_REQUEST['dnd'] == '1') { $dnd='30'; echo 'Set to Available'; }
if($_REQUEST['dnd'] == '2') { $dnd='31'; echo 'Set to Away';}
if($_REQUEST['dnd'] == '3') { $dnd='32'; echo 'Set to Out of Office';}
if($_REQUEST['dnd'] == '4') { $dnd='33'; echo 'Set to In A Meeting';}
if($_REQUEST['dnd'] == '5') { $dnd='34'; echo 'Set to On Site';}
Thanks,
John
[email protected].
