How to create a new trunk template on the secure trunk port 5061 for my provider cheapconnect
Gerards
I just installed a clean version 16 of 3cx on my dedicated virtual windows server.
Certificate is generated with the inital setup process.
But when i want to enable the SIP a trunk on a secure port for my SIP provider i am unable to.
i actualy only want to open up port 5061 from my firewall to th 3cx virtual PBX.
So i imported a template from a working config and simply changed the default portnumber 5060 to 5061
Does anybody have a step by step manual on how to creat a new trunk which using secure SIP port 5061 (preferably with my provider cheapconnect).
Kind Regards
Gerard
Hi Genard,
You should wait for Update 3 that is coming out soon. You can preview the alpha version if you wish (for non production systems) which includes the ability to enable Secure SIP transport over TLS. You provider will have to give you a certificate that can be added in the PBX
12378
bosdorf
