Solved How to create outgoing rule for +49 1520xxxxxx
Vettel
what must be the outgoing rule for +49 1520xxxxxx?
I created this following rule, but I can´t call out.
On my Snom Phone I get the error "not found".
Depends on your provider and how they want the numbers.
Provided that the issue is that the rule is not being matched note that for this rule to match it means you would have to dial a number starting with the + sign. Are you able to do that from the snom? What exact number are you dialing from the ip phone?
To determine if the rule is being matched you can check the 3CX Management Console Event log, you should see a warning or error when the call fails, the info there should shed some light on the matter.
The phone calls exactly the number +491520xxxx. In the 3CX Call History I can see this call also with this number and the status is "not acepted".
Have you checked the Management Console's Event log too? What do you see there? It may be what @bitn2 and it is the SIP Provider rejecting the call.
How can I check the Management Console´s Event log?
Thanks!
In the Management Console just go to "Dashboard" on the left menu and you should see the "Event Log" on that screen. You can click on the settings (cogwheel icon) on the right to determine what is shown:
When its Telekom than they want the numbers in international format. +4912345679..
e.164 must be switched off. Here are mine for german Telekom:
Nummern mit Präfix: 00
Ziffern entfernen: 2
Ziffern voranstellen: +
Ziffern entfernen: 1
Ziffern voranstellen: +49
Nummern mit Präfix: +
Ziffern entfernen: 0
Ziffern voranstellen: <leer lassen>
Nummern mit Präfix: 1-9
Ziffern voranstellen: +49<Vorwahl ohne führende 0>
@bitn2 Danke für die Übersicht.
Meine Regeln sind identisch nun konfiguriert, allerdings ist das Problem immer noch vorhanden.
Mein Provider ist die Deutsche Telefon.
Dieser verhält sich technisch in vielen Bereichen ähnlich wie die Telekom.
Somit ist das Problem sehr seltsam.
Ich habe jedoch folgendes festgestellt:
Wenn ich die 01520xxxx anrufe, wird die 0 erfolgreich durch +49 ersetzt und ich kann rausrufen.
Somit kann es kein Provider Problem sein, da es hiermit ja funktioniert.
Haben Sie noch eine Idee?
Die Regeln werden der Reihenfolge nach abgearbeitet. Wenn die nun alle so eingestellt sind, dann solte das funktionieren. Ansonsten bleiben nur die Logfiles um zu gucken was bei +4912346 passiert.
First off, I do have to mention that we'd appreciate keeping the conversation in English as these are 3CX's International forums this information will definitely prove useful to other members too.
Now, it sounds like the number might have been reformatted before it reached the Outbound Rule. Can you go into Settings E164 and disable the following in the provided order:
Note: I know the below options will turn grey when you disable the top one but please do use the order I mentioned above regardless.
Ich habe den Fehler gefunden :).
E164 war noch aktiviert.
Danke für die Hilfe!
Reactions: ChrisC_3CX
Sorry, for speaking german. The rules should be correct now and after he disabled e.164 everything works.
No worries!
Glad to see you got this sorted! I'll be marking this as solved so please do let us know if you need anything else!
Mr_IT
