Solved How to enable/disable SIP Trunks independently?
VictorSP
Platinum Partner
Hi team,
Is there any way to enable/disable a SIP Trunk independently? We have a scenario with 50 SIP Trunks at least and for testing we want to enable just one or two of them for incoming calls, but it's not possible, there is not a button to enable just one. Editing the rest is not a solution because it would take too much time and work, and exporting them is not also other solution because we cannot export all at once.
Any idea?
Regards,
Víctor
Hi @VictorSP
To enable or disable a single trunk the only thing you need to do is to enable/disable these 2 options under each trunk.
It is essentially what the disable/enable all buttons change in the trunk settings.
Hi @VictorSP
Hi @YiannisH_3CX
That option would be great if the SIP Trunks could be mass-editable all at once but it's not possible, the EDIT button is disabled when you select all the trunks so, I have to deactivate that option one by one.
It would be great if there was a button to just enable/disable the trunk directly from the list.
Thanks for your reply and help!
Reactions: YiannisH_3CX
lastshadow
