How to export import personal contacts? It's a tragedy.
Gianpiero Pi4you
Hello EveryOne,
You have push to go for micro company in Multi Tenant version, in more case we need to move users (fulle rebiuld ), but the big tragedy is impossible to moke personal phonebook.
I have spent 2 hrs to push out old phonebook , no export, with Copy PAst, Script in XLS I have create a Good CSV to import.....
next impossible import from web!!
next I have find import personal phone book is enable on Plugin... good, I'm happy!!
next other TRAGEDY, limit import contacts is 500!!!
next 20 hrs to Copy and Past , One by one, all by hand!!
I don't think is a big issues , spent 10 hrs to fix this BUGGGGGGGGGGG!!
Hi Giampiero. Same issue here. Hope someone can fix.
Hi Giampiero. no updates from support?
Hi.
For the Personal Phonebook there is no ability to export the entries in a .csv file.
This would help, to move persons to another extension.
If you use 365 or Google, I would suggest syncing their personal contacts this way to make it easier.
T2T
