How to fix extension with same number already exists
Do Hung
Forum User
Hi everybody ! I am having a problem, when I create a new account. but "existed" error. but when I searched in other categories I couldn't find it. hope everyone will support
You could try doing a call report for this extension and see what comes back?
also, you're on an old version of 3CX and i would recommend you upgrade to V16.
You are using a very old and deprecated version of 3CX. There will not be any support or bugfixes for it, so your best bet is to look into replacing it with V16 and also moving to a modern OS.
thanks for your support. But here's the problem: I generate other numbers that still succeed. just creating that number won't work. although I searched all of the items
hughesdouglas
