how to get a multi tenant license?
Song
I was watching the 3cx multi tenant webinar and to get a multi tenant license you need to do the following step:
1. login to your portal and click on the 3 dot.
2. choose download and select install on the multi tenant
3. it bring me to a purchase screen. I click on order
4. do i select 3cx PRO 16 license?
5. can i also select hosted by 3cx?
6. do I just check out and everything will be good?
please advise if this is the step to get a 3cx multi tenant license. or get a instance installed with multi tenant. I'm a bit confuse.
thank you
So basically you need to have your new 16SC ENT/PRO and above key purchased.
You go through the installation steps to download but you select the multi-tenancy option then select your license.
https://www.3cx.com/docs/multi-tenant-configuration/
Im not sure if hosted by 3CX is an option but I guess you'll know when you go through the motions.
Reactions: NatalyS_3CX
@Song In order to deploy a 3CX Multi-Tenant license, you will need to Self-host or deploy on-premise. It is not possible to install it in the 3CX hosting environment, so make sure you do not purchase our Hosting when you buy the license.
As @Alphabetic has already shared, the configuration guide walks you through the necessary steps for installation. Please note, when deploying a Multi-Tenant license, you will need to do this from the Downloads page in your partner portal NOT from the My Systems page as is the case for Dedicated installations.
No members online now.
DejanMDS
