- Joined
- Jan 23, 2023
- Messages
- 64
- Reaction score
- 2
Do you mean Inbound Rules? And is this the only place DID's are used?Export all incoming routes and then compare them to the list of DID's you have?
We want calls made to a number not owned by us to be forwarded to our number. And we want to know which carrier numbers we don't use so we can choose oneIt depends on what you mean by used. The inbound rules is where you will find numbers that are not directly assigned to anyone.
Note:
If you go to add a DID Inbound rule and you expand the "DID/DDI" drop down menu then what you get is the list of available DIDs.
DIDs that are not in any other inbound rule
The number that does not belong to us will be forwarded to us by its ownerWhat? When you dont own the number, you cant forward it to somewhere else. The second part i dont understand.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
