grayedfox Forum User Joined Apr 17, 2019 Messages 16 Reaction score 0 Apr 24, 2019 #1 Hi there, I would like to be able to enable/disable scenarios (or an entire integration) based on the SIP trunk that is in use. Is this possible?
edossantos Support Team Staff member Joined Jun 27, 2007 Messages 7,804 Reaction score 2,950 Apr 24, 2019 #2 Unfortunately this is not possible at the moment. There is no variable you can use for this.
grayedfox Forum User Joined Apr 17, 2019 Messages 16 Reaction score 0 Apr 24, 2019 #3 Okay thank you, this thread can be closed. Cheers
