How to only open browser tab on answering a call
kevjones
New User
Hi all,
I am working with a client and we have successfully integrated 3CX with our CRM using the CRM Template Wizard which now opens a new browser tab with a customer's record in it matches the incoming caller's number.
However, our client have a number of users concurrently logged in to 3CX, and whenever there in an incoming call, all user's browsers open a new tab.
Is there a way to configure the API so that this behaviour is only triggered for the user that answers the call?
Many thanks in advance,
Kev
Hi all,
Kev
Unfortunately, no, the server-side integration works this way and it cannot be changed.
What you could use is the Open Custom URL in the Webclient/Browser Extension, and use the 2 available variables to trigger it only when the call is answered.
Many thanks Frederick!
In addition, you can configure the Web Clients > Settings > Integration > Off, and this way no automatic popup will happen. Then, your agents can manually click the contact icon before answering the call, and this way launch the contact record.
costionofrei
