How to protect config files in provisioning folder.
Bpnt
Forum User
Is there any option to protect config SEPAMC.XML files in provisioning folder from outside internet connection?
Config files have login and password as text and only thing that protects it from outside internet connection is random alphanumeric code in provisionig folder path and mac address of device. I think it's a little bit too weak protection. I try to move folder that carry SEPMAC.XML files to another location and change destination in TFTP, it was working but phones starts to unregiser randomly. Is there any solution for this problem.
This may put your mind at ease
https://www.3cx.com/blog/docs/v15-finding-provisioning-files/
First of all, good news! As of V15 it is likely that the provisioning folder does not contain any provisioning files and that a file which might have remained there from an upgrade is not updated.
For security measures the PBX does not store the files on the disc. The reason is very simple, maybe the person administering / hosting your system is not the same person that is in charge of the administration of 3CX. Presenting the config file to these people would be not a wise idea…
hughesdouglas
