How to set different rings for queues
Michelle Dinh
Forum User
The setting is in settings - phone / client
When you have enabled the above, you select the ringtone for each queue under ‘phone provisoing’ tab for each phone
You have to be running 3cx standard templates - no custom templates
Reactions: YiannisH_3CX
To have the option appear, your extension will need to be a member of a queue
What if a user is in multiple queues? How do we distinguish?
Ideally I would want to assign a queue a ringtone so if a user if in multiple queues, they potentially can get two different rings on their phone. Is that possible?
Once you enable the option you will be able to assign a different ring tone for each queue.
You can enable this setting by navigate to the PBX Settings / Phone/client options and enabling the option at the bottom. Then you can set the ring tones under each extensions phone provisioning tab.
To apply the changes you need to reprovision the phone.
Reactions: Michelle Dinh
zipman
