Solved How to troubleshoot high cpu usage?
ElementalWindX
I have a v16 newest version PBX that is stuck at 42% cpu usage non-stop.
What are the best ways to go about troubleshooting a high cpu usage instance of 3cx?
Thanks!
Windows, Linux, bare metal, VM, cloud? Dedicated 3CX machine? Brand new install? Recently upgraded? Any information at all would help.
Linux, VM in a cloud provider. Dedicated 3cx. Been installed for a while. Just upgraded it to the newest version but the graph shows it's been doing it all day before the upgrade.
When I run top, it shows that TKCd-DaemonPer is using 18%~ avg and tkchelper is using 18%~.
For reference this is a Pro 16sc with 18 extensions on a 1vcpu, 2gb memory, 60gb storage vm.
I have another instance with the same setup with 21 extensions and it's only using maybe 4% cpu.
Listing the services it shows:
tkc_standalone_daemon.service enabled
tkc_standalone_helper.service enabled
Can't find anything on google about them.
Ahhhhhhh nvm. I just realized. I installed Solarwinds Take Control program onto this VM.. Completely forgot about it. Interesting that it caused such a huge spike...
Kayla Norris
