How to use Yealink DECT W52P phone?
Kane Wong
Hellow;
The Yealink W52P DECT phone base station support max. 6 handsets linked to it, this is my first time to propose using DECT phone for my office, before implementation; I would like to know when incoming call transfer from operator, what happen to those DECT phone handsets. My understanding is that I can assign different extension number to each handsets, let's say 101 /102 /103 /104 /105 /106... if the operator transfer an inbound call to extension 103, in this case; would other handsets ring too? Each handset function as an individual ip phone, isn't it? Can handset assigned with extension number 101 answer the call for handset extension 102?
Each handset can will handle two simultaneous calls . The base can be assigned up to 5 VoIP accounts (extensions), but will only support 4 simultaneous calls total. Keep this limitation in mind if you t to use 5 extensions and attempt put all 5 into the same ring group. You can assign up to 5 handsets. You choose which of the 5 lines (extensions) are used for incoming and outgoing calls on each handset.
Scroll down to page 44 of this guide.
https://3macae71618368hq3ytkqe1c-wp...ds/2017/02/Yealink_W52P_User_Guide_V73_27.pdf
If this is pre-implementation it sounds like you have the opportunity to test the various scenarios you asked yourself if you already have the hardware. If you set the handsets up as separate extensions, then yes they are separate extensions.
thank you.
On page 44, I also found that one Handset can be serviced by two different extension number, right.
It appears to be very similar to the way the Gigaset IP DECT sets work. You can have any of the registered extensions ring incoming, and choose a primary outgoing, but can dial out on others that have been assigned, by using the Line key.
Reactions: Kane Wong
