Solved HTTP request to open a relay
alexis41818544158
Platinum Partner
I need to do this thing with 3cx, is it possible?
A person calls me and after typing a code on the keyboard I can send a message by opening a relay that opens a door (such as sending an http request to an IP). The relay must not be registered as internal as it must not be reachable from outside but only by me after entering a code (perhaps an IVR). I saw the "launch script" type function, could it be useful?
Thank you
You can do this with a CFD app, using the HTTP request component.
Sorry, I'm reopening the post, I also have a web relay that opens with this type of http request, from any browser:
"http://xxx.xx.xx/state.xml?relay2State=2"
I have tried several times to configure a flow with only http requests and connecting it to an extension, when I export the project to 3x to make it work, but it doesn't work.
I configured it like this... where did I go wrong?
Remove content and content type. GET query should be in the URL itself, not in the content field which is for POST requests.
Reactions: jed and auxilium
Perfect, it works, thank you very much for the support!!!
Reactions: jed and Evolute IT
Glad to know this is resolved ;)
Reactions: auxilium
cur_cb
