http/s not running after first config
AK-47
Trainee Partner
I've just run up a system in Azure. Everything went fine until after initial configuration.
Using my own certs and FQDN.
service --status-all claims all services are running.
nginx isn't running and fails to start with an error.
.pem files are in the /var/lib/3cxpbx/Bin/nginx/conf/Instance1 directory.
I can't connect from either the local IP from the jump box nor the public IP (obviously because nginx is not running).
I've read a lot about similar problems but not certain where to go from here.
Thanks. That somewhat aligns, however this certificate appears intact and is not a renewal. I'll try re-keying the cert to get fresh crt and key files and give that a shot
As expected that didn't help. But it did put me back on the right path. It seems that it didn't like my key file. Saved out the file ensure UTF8 and voila.
Thanks for pointing me in the right direction.
erre
