Solved I don't have server side integration tab for HubSpot
dandumit
Forum User
HEllo All,
I have managed to install self hosted, 3CX Debian version latest available version. I have requested free upgrade to 3Cx PRoffesional.
Next step is to integrate HubSpot. Unfortunately following the integration description I cannot find on my management application the tab for "Server Side Integration" ,
I have only tab "Client Side integration".
Please suggest what to do next.
Thank you,
Daniel
You might need to refresh the license.
Check your Dashboard, on the Edition (3rd column), if it says Standard or Pro.
If Standard, click the little refresh icon on the right, refresh the whole page then go back to Settings > CRM and the tab should be there.
Thank you @ConceptsWeb . Followed your lead and worked.
Worth mentioning that there are some licence reading on settings as well.
I have pushed licence review from main dashboard. .
an admin please close as solved.
Thank you,
Daniel
