Solved I have a client on the cloud with version 18 and I will move this client to another cloud provider with version 20
samehJABRI
I have a client on the cloud with version 18 and I will move this client to another cloud provider with version 20,
how can I do that?
Best Regards
Ensure first that the PBX is on the latest build of V18 and all steps of this guideline are followed.
Then just create a full backup and restore it while installing the latest V20 ISO.
The PBX is in the latest version v18, from which I took a backup. I created a PBX V20 that runs on Windows, and I put a backup. However, when I attempt to log in, I am not granted the necessary permissions. Login and password are incorrect. Knowing that it is correct, I log in with it on the old PBX.
In V20 you need to login with the credentials of the assigned System Owner extension and the email of this user must be unique.
Yes, he has the advantage of being the owner of the system and the email is his own unique.
Did you add the IP of the new location under console restriction before you took a backup?
try logging in to the admin console from the old location.
What is the exact error?
Have you reset password?
the problem is solved, thank you
tom.walker@blackcountryra
