I think bad people are trying to hack into my phone system
BusySignal
I received an email from my 3CX PBX that the IP address for my SIP provider had been blacklisted. When this happens my phone system becomes an island. No calls from outside world come in, and no calls to the outside world go out.
This has happened once or twice a year for the last few years. Bad people come in from the SIP provider's network and attempt to create an extension on my phone system. The registration fails because the bad people don't know any of the user names and passwords for existing extensions. I delete the blacklisted IP, we're reconnected with the outside world, and things are ok again.
This time however, my event log is chuck full of 10029 Provisioning file for MAC <<MAC address of an extension on my system>> of user <<extension #>> requested by <<IP address of some other extension on my network>>.
This is more than a little bit terrifying because if the bad guys obtain a provisioning file, I think they'll have pretty much everything they need to setup a rogue extension, and start doing who knows what with it.
I deleted the blacklisted IP, and the event log immediately started filling up with these 10029 events again. I disconnected the network cable from the SIP provider for about 30 minutes, reconnected it, and I'm now watching the event log. No 10029 events have shown up yet, but I'm sure it's only a matter of time before the robotic program circles back to my IP or the bad people get back from lunch or whatever and continue their nefarious hacking.
My question to all my forum friends out there is: How can I stop this? Is there anything I can do? Are the bad guys getting the provisioning files of all my extensions and I'm just doomed or what?
"Others" are constantly trying to place direct SIP Calls or register an extension on SIP PBXs, we all see it. That is the problem with having a SIP port exposed to the internet. You can use a proper firewall to block a lot of the undesired traffic, or restrict it to certain IPs, you can also be sure that your passwords are not easily guessed.
3CX , on its own, is pretty good at blocking bad actors, but it is not a firewall.
I blacklisted the SIP IP on the first system I ever set up because of a typo, so now we Allow those IPs during initial configuration.
Ensure the 3CX global blacklist is enabled, which it is by default. As mentioned we also restrict ports if possible and run IDS in front of all servers we host.
Edit: I guarantee you bad people are trying to hack into your phone system. :)
saw-nick
