IF_TWO_LINKS_START Variable change
princer800
Gold Partner
I recently created a stub domain in our DNS to allow the External FQDN to work inside of the network.
so https://my3cxserver.ia.3cx.us resolves correctly to the internal IP as expected.
Works perfectly to insure there is not certificate error - which for this customer was a big deal.
Now I want to change the Welcome letter to not display the internal URL. Instead of hacking up the HTML code it would appear that by chaning the variable IF_TWO_LINKS_START would make sense. Found one post - but never a answer on if or where that can be done. Does not show up in the parameters as a parameter.
Or - if it can be changed if there are side effects that might make that less than desirable.
Otherwise a hacking we will go - been there done that for sure.
So I think doing a backup and restore and using the 3CX FQDN for the internal option is probably the best bet.
florentrobineau
