Iinet Australia on 3CX - Outbound Caller ID?
bannerj
Hello all,
Is anybody running 3CX with Iinet as their sip provider?? Yes I know they are unsupported, but I just have a small issue. Calls are fine in and out, however the outbound calls have no caller ID and show as "private number". This is becoming a problem for the user.
They were on a Grandstream 6xxx appliance for years, outbound CallerID was not an issue. As the system died unexpectedly, I spun up a 3CX to get her out of trouble and she is now happy enough not to replace the GS and stick with 3CX. Her only beef is with the outbound CallerID.
I have tried changing settings in the extension, as well as in the outbound parameters of the individual trunks. The only think I haven't done is bounce the system each time, but the trunk has re-registered with no change.
Has anyone else had this issue and overcome it? This is the first time I have set up 3CX using the generic trunk.
Have you used Wireshark (Activity Log?), to see, in what field you are currently sending caller ID (and confirm you are sending it), and checked with the provider as to where they expect it?
hughesdouglas
