Solved Import Inbound DID Rules fail
Delo123
We are trying to bulk import Inbound rules for 2 reasons
- Not having to create each import rule manually
- So the DIDs are imported to the trunk
The import fails on all rows with error (PORTS/MASK)
If we go into the trunk first and create the DID by hand the import works, but we do not want to create all DIDs manually since adding a range isn't possible anymore.
How can we import BULK DID / INBOUND rules?
Sample:
2,401,1,+31XXXXX401,[10000],2,401,0,0,,,2,401,0
3,402,1,+31XXXXX402,[10000],2,402,0,0,,,2,402,0
Should someone else stumble upon...
Got it, we had deleted a trunk and added another, so ports is actually the trunk number, had to change to 100001 now it's ok...
Glad to see you managed to resolve the issue and thank you for updating the thread with your solution.
Reactions: Delo123
jlucero
