Solved Inbound Caller ID settings for Voip.ms
mobilityproject
I'm using Voip.ms for my SIP Trunk and everything works fine, except 3CX (15.5) isn't receiving the caller ID name (CNAM) that is passed through from Voip.ms. Anyone know what I need to do to get that working?
In the call records on the Voip.ms site, names are presented as:
"WIRELESS CALLER" <5555551212>
Do I need to set something up in the 'Source Pattern' / 'Replace Pattern' section?
Hello @mobilityproject
If the CNAM lookup is enabled in Voip.ms portal then you will need to change the "CallerName" value to "From : Display Name" in the Inbound Parameters tab of the trunk settings.
Glad to see the issue has been resolved
maurin.roffler
