Inbound calls hanging up after 32 seconds
Kamsky
Hi, I perform my first 3CX installation week ago and had a lot of problems. The biggest one is that every inbound call hang up after 30-32 seconds. I have a internet provider router and mikrotik routerboard in my network. Firstly I make mikrotik router DMZ and it worked. But next day problem came back. Yesterday I disabled SIP alg on mikrotik and on Dasan router from my ISP. And it worked, but AGAIN only until today. I have no more ideas what to do with that case. For your information I forwarded all the remaining ports.
Calls terminating at 32 seconds is usually a sign that the 2 sides are not able to communicate correctly, and something is probably blocking the traffic.
I would recommend to run the 3CX firewall checker first and tell us what the results are
Could be that the link is timing out. I encountered this on my Sonicwall firewall. I changed the UDP Connection Inactivity Timeout to 600.
Turn off sip alg in your router/firewall. Better yet is go through the 3cx beginner training. This is one of the most common problems. Not trying to be rude or anything but it is one of the first things you will learn. Good luck 3CX has great training videos
Translated from the Italian blog: https://www.3cx.it/blog/docs/timer-sip/
(I didn't find it in the English blog)
What are SIP timers
Blog Author Posted on April 9th, 2019 by Matteo Sala, Training and Technical support for VoIP & UC
SIP timers and VoIP call drop One of the most common error situations in the field of VoIP SIP telephony concerns the sudden drop in calls at 32 seconds.
This is related, in more than 95% of cases, to problems or errors in the configuration of NAT.
To understand why this type of error occurs, it is necessary to introduce the topic of SIP Timers.
The SIP Timers and the drop of calls to 32 seconds. The SIP Timers T1, B, and F are used to primarily determine the time it takes for the remote device to respond before the sender considers it a timeout. That of 32 seconds is a fairly common call drop interval and is essentially dictated by the action of the so-called “SIP timer”. Here's what happens in detail: The Types of SIP Timers: T1, B and F The T1 timer is the estimated round trip time of an IP packet, and the default is 500ms for almost all SIP systems. Timer B is the maximum time the sender will wait to receive an INVITE. Corresponds to a value of 64 times the value of T1. Timer F is the maximum time the sender will wait for non-INVITE messages. Corresponds to a value of 64 times the value of T1. B and F are doubled with each iteration and so an unanswered INVITE will look like this: T0 - sending of the original INVITE. 500ms - sending of the 2nd INVITE. 1000 ms - sending of the 3rd INVITE. 2000 ms - send of the 4th INVITE. 4000 ms - send of the 5th INVITE. 8000ms - send the 6th INVITE. 16s - send 7th INVITE. 32s - send the 8th and the last INVITE. The call is interrupted. Here is therefore explained the reason for the failure of a 32sec call. Why does the error occur? This phenomenon occurs because NAT is not working properly. In most cases this is because routers / firewalls prevent ACKs from passing through. In this situation, the SIP type B timer comes into play, effectively interrupting the call when the 32 seconds expire. The settings of these Timers can probably be compromised by an incorrect NAT setting at the PBX level or at the telephone extension level.
In these cases, it is advisable to run a Firewall Test with the appropriate 3CX functionality and search for the presence of SIP ALG or incorrect NAT configurations.
Here is screenshot from firewall check. I also checked that SIP ALG is disabled on both routers.
Thanks, this is a critical check that your installation needs to pass.
Your 5060 port does not appear to be properly forwarded.
Can you check your firewall setup and ensure 5060 UDP/TCP is forwarded correctly?
Run the checker again after you finish to confirm the results.
What's the next hop after your firewall? ISP modem?
Does the ISP allow you to use 5060? Is the NAT/Bridge mode on the ISP modem taken care of?
hughesdouglas
