Inbound calls that don't match trunk, what happens?
dandenson
SOHO User
I'm looking at my trunk config, which is with VoIP Innovations. I've got one inbound trunk and I've whitelisted their other IPs.
When I look at inbound rules, I see that my main DID appears to be tied to that trunk. What happens when a call comes in outside of that trunk from one of the whitelisted IP addresses?
I have other threads on the symptom (random calls go direct to voicemail, no network issues) but different angles. I'm wondering if the call comes in from a VI address that doesn't have an inbound rule, does it get handled by the system default? ie settings/pbx/operator extension? I have that set to a voicemail only extension because it won't allow me to set it to a ring group.
You should based this on DDI and not IP address. If you have a block of DDI's then you can add them in on the tab in the trunk configuration.
There are two types of provider - IP authenticated and registration based, please advise which yours is.
For an IP authenticated SIP trunk, only 1 IP address is permitted and must be allowed through your local firewall to 3CX (the provider does the same on their side)
Voip Innovations is IP based. They have multiple IPs so I need multiple trunks. Different IPs for in and out and for redundancy.
The complication in 3CX is that if I want to use the same outbound DID in all trunks, I've got all these duplicates.
Sounds similar to Gamma assured SIP service that we have here in the UK.
Not good for setting up with multiple IP addresses but I recall that there is a fudge you can perform by setting up with multiple trunks and assigning different SIP Id's.
Let me start first by saying that they are not supported right now.
Knowing a bit how they work, you would have to:
  • Create 1 SIP Trunk in 3CX for each of their IPs (enable Source Identification in Inbound Parameters tab with "Contact : Host Part" <==> GwHostPort). I think you should end up with 8 SIP Trunks last time I checked.
  • Each one of your DID, add to all SIP Trunks (you don't know which IP it'll come from)
  • Create the same Inbound rule multiple times, once for each SIP Trunk.
Before someone says it, there is a reason we have not announced them as approved to use on 3CX.
This MAY work, but it would be a bit of a nightmare to maintain.
I use Innovations with more than one ip, in endpoints just add another ip to the group. https://backoffice.voipinnovations.com/Dashboards/Endpoints.aspx , you can even test it by just changing the priority.
For voipinovations i only use the 64.136.174.35 address which is not optimal from a redundancy point of view.
You could get a $50 edgewater 4550 off ebay with a sip license and setup ip based registrations for all innovations ips, and if this works then order the must more costly multi wan edgewater for your multiwan setup.
Reactions: NickD_3CX
fngl
