Solved inbound cname
cbroessel
my inbound cname shows up in the call log, but not on the phones, it just shows the number. any ideas?
Hi @cbroessel
You mean the callers name from inbound calls to the PBX? If that is the case then check your inbound parameters of the trunk and make sure that you are reading the info from the correct SIP header.
Are you using a 3CX supported provider? If so who is it?
Also what phones are you using? Can you replicate on a 3CX Web Client?
It was user error, they were talking about the caller id app on their computer, they weren't looking at the phones. thanks for the help though
Reactions: YiannisH_3CX
