Inbound direct call for user A is replaced and send to user B (⋟﹏⋞)
acontreras
Hosted on Amazon
OS Debian
Product Professional Annual
Version Number 18.0 (Build 312)
Client 3cx APP iPhoneVersion 18.6.2
Sip trunk Provider: Telnyx
Problem:
Extension has a direct number, we call the direct number, the call is sent to the EXT 1307, but the call get replaced by Ext 1305, this happens a lot and we not sure how to fix it.
04/28/2023 10:42:50 AM6304Paul (1307)00:05:57
04/28/2023 10:42:22 AM6304IVR (8002)00:00:20
04/28/2023 10:42:10 AM6304Janet (1305)Not Answered
04/28/2023 10:42:01 AM6304IVR (8002)00:00:09
04/28/2023 10:40:39 AM6304Janet (1305)00:01:13
04/28/2023 10:40:17 AM6304Paul (1307)00:00:02
This only happens between these two extensions, both extensions rights are set the same, we have one main ring group but only extension 1307 is part of the main group and it's a different inbound route.
Logs:
04/28/2023 10:53:46 AM - [CM503021]: Call(C:1697): ACK is not received from sip:[email protected]
04/28/2023 10:45:06 AM - [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
04/28/2023 10:42:50 AM - [CM503003]: Call(C:1693): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Cancelled/INVITE from 127.0.0.1:5080
04/28/2023 10:42:50 AM - [CM503003]: Call(C:1693): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/28/2023 10:42:12 AM - [CM503003]: Call(C:1692): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/28/2023 10:40:38 AM - [CM503003]: Call(C:1690): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/28/2023 10:40:17 AM - [CM503003]: Call(C:1690): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:548
Anyone has any advice?
Thanks in advance :)
Antonio
First of, make sure you're up-to-date on the PBX side.
Also, what phone/softphone do you use for this testing? If a physical phone, maybe someone configured a call forwarding on there. I'd also check the forwarding rules for both users.
Reactions: jed
We are using iPhone app the Kate’s version.
This only happens when direct number is dialed not when you dial between extensions.
No forwarding rules.
Thanks for the assistance
Kayla Norris
