Inbound Office Hour
2024ehf
Hello. On V18 i set Office Hour on Inbound Rules. Now it is like it is always using that after i Updated to V20. And now it always uses that Hours. How can i fix that?
It should use department hours, but, you may need to assign your digital receptionist to a department (can be DEFAULT), and also add closed/holiday/break routing to your digital receptionist because it defaults to the "open" routing.
in Office Hours i have Nothink and shut be able to get calls but still it gose strait to Voicemail seems in V18 i set it in Inbound Rules and did not remove it before updating to V20
Also it is like all Exstensions just gose strait to voicemail.
Hmm, our own server defaulted to "always open" so that sounds like the opposite issue. So have you:
  • assigned office hours to your department
  • assigned ring group to department
  • set call routing in the ring group
  • assigned digital receptionist to department
  • set call routing in the digital receptionist
Yes. But still the same.
georgi
