Solved Inbound rules not bypassing digital receptionist
Grumbles
I have set up a inbound rule to go straight to an extenisons voice mail.
When calling this DID, it goes through the digital receptionist. Ive tried this with other inbound rules/dids and it worked before, but now it doesnt and im not sure why.
Hi Grumbles
Does the inbound rule match though?
Is it a DID or a CID rule?
If nothing matches, you would get the call routed to where the trunk routes calls by default (which I imagine is the digital receptionist)
Check logs and see what number is being presented to 3CX.
Adjust rules to fix number , note you can use * in rules. For example *654321 will detect 987654321
Hi Grumbles
Hi JohnS_3CX,
I have added the number as a DID in the trunk and added the number as a DID Rule.
I found the issue.
The inbound parametres in the trunk had to changed to default.
The Inbound rules are working now
Reactions: JohnS_3CX
intoxtech
