Incoming call issue [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification
jabir
Forum User
I can make outgoing calls from 3cx app but cannot receive incoming to my extension. I have setup a gateway (in 3cx) to cisco router (cisco router is connected to PSTN via FXO).
I am using 3cx version 16, locally hosted on windows server 2019.
router configuration is as below:
voice-port 1/0/0
no battery-reversal
input gain 10
output attenuation 10
no comfort-noise
timing hookflash-out 50
connection plar opx 2222
description trunk 0202204882
caller-id enable
dial-peer voice 1111 pots
description outgoing calls to 3cx
destination-pattern 8000
incoming called-number .
port 1/0/0
forward-digits all
dial-peer voice 3333 pots
description calls from 3cx to voice port
destination-pattern .
port 1/0/0
forward-digits all
dial-peer voice 1 voip
description Outgoing calls to 3cx
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-interworking rtp-nte
no vad
dial-peer voice 2 voip
voice-class codec 1
no vad
below is the incoming call log from 3cx activity log:
also a snapshot of Gateway:
But it's not matching thus why you need to read the links
Reactions: jabir
tried different combinations as given in the link. Below is the configuration that changes the log from activity log:
below is the actual log from activity log:
but still can't receive calls
For anyone who might have the same issue and is searching for it. router configuration is correct, the only mistake i made was that i was creating Gateway instead of SIP Trunk in "SIP Trunks" menu tab. create SIP trunk and create inbound rule and you will start receiving calls.
3K8iMGWviZ
