Incoming calls dropping at the 3 minute mark
Michael Menor
Has anyone experienced this issue where an incoming call would drop exactly at the 3 minute mark? This also happens when an incoming call is Parked, then picked up by the end user - it will end at the 3 minute mark. VERY FRUSTRATING!!
A little background on the setup:
  • Incoming SIP trunk is provided by CallCentric
  • "Support Re-Invite" is disabled under the Options tab
  • 3CX v15.5 SP6
We have opened a case with CallCentric Support and this is their response (highlights are in bold):
Generally speaking, with the "Supports Re-Invite" setting disabled the 3CX trunk shouldn't forward Re-Invite packets towards the SIP trunk externally. Reviewing the example with the call from 18xx2xxxx91 on 12/9 at 20:33 GMT we can see that the same issues occurred in relevant to Re-Invite packets from 3CX:
INVITE sip:[email protected]:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-524287-1---44541a44216cb012;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: "John Doe" <sip:[email protected]>;tag=cj2y3Sa2FK3ZF
From: "Jane Doe"<sip:[email protected]>;tag=e22ff441
Call-ID: f26bafde-9565-1238-60b6-0010e0690d2e
CSeq: 3 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 15.5.15502.6 (15502)
Content-Length: 226
v=0
o=3cxPS 2684354560 508735520771 IN IP4 xxx.xxx.xxx.xxx
s=3cxPS Audio call
c=IN IP4 xxx.xxx.xxx.xxx
t=0 0
m=audio 9530 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=sendrecv
In addition to your example from the number 18xx2xxxx91 yesterday after you disabled the setting for Re-Invites we located a more recent example such as the call from 18xx396xxx9 today at 20:02 GMT where the 3CX is still sending our server the Re-Invite packets such as:
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-524287-1---c260d415d2716837;rport
Max-Forwards: 70
To: "JOHN DOE" <sip:[email protected]>;tag=Kgr9avrpFZv0p
Call-ID: e4dfa74f-962a-1238-1b98-0010e068b4de
CSeq: 2 INVITE
Content-Length: 228
v=0
o=3cxPS 336953606144 240048406530 IN IP4 xxx.xxx.xxx.xxx
s=3cxPS Audio call
t=0 0
m=audio 9570 RTP/AVP 0 101
a=fmtp:101 0-16
a=sendrecv
If possible please contact 3CX support in regard to whether it's a known bug where Re-Invite packets are still forwarded externally to the SIP trunk even with the "Supports Re-Invite" parameter disabled.
Normally 32 seconds is the calling card of SIP ALG being enabled on the firewall. Although this is 3 minutes I would still check the firewall as it sounds like a port is being closed after a certain duration of time.
What make and model is the firewall and does the firewall checker pass inf front of 3CX ?
I can confirm that SIP ALG is disabled.
This particular client has a Cisco RV320 and yes, the firewall checker does pass.
Run a PCAP from the PBX of the call with audio proxied via the PBX, replicate the call and let's see where the BYE message is coming from.
Check your session timer value in your firewall.
Another update on this. It only happens when an incoming call is parked. When the call is picked up from park, it will end at 3 minutes.
I will be checking the firewall's session timer value to see what it might be.
Session timeout is set to: 1800
13530
Looking at packet #907033. Does this mean that caller "TOP / 4248" is ending the call to extension 223?
13543
Call Flow
13544
natedog
