Solved Incoming calls not ringing to correct extension and DID
AlanGrnja
Configured extension 001 with specific DID... when I call the DID it just rings and rings. Does not show on my web client ext. 101.
Check the 3CX Activity Log right after a failed call. That should show the DID number being sent. It may be, that the number in the rules. is not an exact match with that number.
check the activity log for the correct format of the DID number being passed to 3CX
You may have to enter *12345 as the DID number (for example, * is a wildcard)
Have you setup inbound rules for the DDI, as entering the DDI under the extension is for outgoing calls.
https://www.3cx.com/docs/manual/inbound-did-call-routing/
OverrideExt.001 has inactive profile override ?
Nothing in activity log about incoming calls....it just rings for about a minute then disconnects
If there is no Activity Log regarding the call, then it is not being sent to you. That being the case, I would contact your provider, and have them trace the destination of the call.
vendor stated "I am seeing a Proxy Authentication Required that is failing the call.
Is the DID listed in the incoming rule list as Saqqara mentioned?
yes routed to the extension 001
Did you use a * in front of the number?
Spoke to provider.. under sip trunk Type of authentication i changed it to register/Account based was on ip based(document i had showed this) . Now incoming calls come through.
Thank you everyone for the help!
Reactions: YiannisH_3CX
I didn’t mention that because you had sorted out the truck registration on your outbound forum post ...
That's the strange part because i was able to make outgoing calls so it threw me off.
Glad to see that issue has been resolved and thank you for sharing your solution in the thread.
