Solved Incoming SMS/MMS messages not working on 3CX v18.x
TPR3CX
Greetings,
We received reports of incoming SMS/MMS texting not work. Since we haven't deployed texting yet, we are not sure when the issue started. We can text out, but incoming does not work.
When I do a TEST from the main Messaging section in the admin portal, I receive the following error:
The PBX is not reachable via the Internet. Ensure that all necessary ports are open and that the firewall check is successful. The error code received is: UNABLE_TO_VERIFY_LEAF_SIGNATURE
Have there been any recent changes to the required Firewall Ports needed to be opened or is this a different issue? Is there an update document that lists what ports I should have open?
I should also add that I contacted Flowroute for help and they said that they are getting a bad request when trying to access the webhook link that is configured, pointing to
Thanks!
Glad you got it figured out!
Yes having the full Certificate chain is very important.
For future readers, a good way to check is using https://www.sslshopper.com/ssl-checker.html, it will tell you if there is something missing or not.
jasonkkrause
