- Joined
- Jul 1, 2016
- Messages
- 6,676
- Reaction score
- 2,668
I'm fairly certain that the date/time values that are in the individual columns are being converted by Excel, or the corresponding program you are using to pen it with. The value at the top, because it isn't in a cell by itself, Excel doesn't detect it and convert it.The HTML report shows the time as AM/PM but the CSV export is using 24 hrs
I'll agree on the time showing that way. But, what about the date format?I'm fairly certain that the date/time values that are in the individual columns are being converted by Excel, or the corresponding program you are using to pen it with. The value at the top, because it isn't in a cell by itself, Excel doesn't detect it and convert it.
Open the file with a normal text editor like notepad and check the format like that.
sudo dpkg-reconfigure locales
sudo 3CXStopServices
sudo 3CXStartServices
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
