Inquiry Regarding Migration from Self-Hosted 3CX to On-Premise License
Aphisit
Platinum Partner
I have some information I would like to know, could you please assist me
If a customer is currently using a self-hosted 3CX system abroad and would like to migrate to a 3CX on-premise license, is it possible to back up the existing system and restore it to the new environment while continuing to use the same FQDN and existing data?
Best regards,
Aphisit
With regards to 3CX both systems are externally hosted, so there should be no issue moving from one to the other via a backup.
Thank you so much for your support.
You could even set up your 2nd server in standby and then make the switch.
Reactions: KyriacosS_3CX
arming
