Inserting calls into Microsoft SQL
Iaan
Forum User
I need to insert calls that are made into a Microsoft SQL database. I used the CRM Integration on my 3CX server and Enabled Call Journaling but it doesn't insert any calls into my database.
What am I doing wrong?
Please note that this only works when your database returns a contact during lookup. Call Journaling entries are bound to contacts, so this is a requirement.
If you need to add all your calls to your database, please consider importing the information from the CFDs generated by 3CX:
https://www.3cx.com/docs/cdr-call-data-records/
costionofrei
