Install 3CX without remove Apache
erpardeiro
Hi!!
Recently I try install 3CX in a server with an apache application. My problem is that when 3CX install starts, a message informing that Apache2 will be removed to continue appear. See below:
The same problem occur when 3CX it's installed and try install Apache2. See below:
Ok...ok.... I know that the recommendation is install 3CX in a dedicated server, but I need know that this possible or not.
Technically, this is possible, but since you didn't know that nor how to do it, I recommend not doing it and sticking to the 3CX recommendation.
Hi @cobaltit !
Thanks for your answer. After very read and research, decide that is no good idea.
Good week for you!
Oliver Hastedt
