Install Old 3CX SBC
Rhys Haskell
How can I install the old version (15.5) SBC?
Thanks,
Rhys
Hi Rhys,
If you install it via Debian you can force install a previous version
apt update
apt-get install 3cxsbc=15.5.9414
look at the output carefully, it will tell you where to look for the SBC config file when you are done so your can set it up manually
Correct, this is a mistake, the link is from the same page PBX and SBC reside on, well spotted.
Reactions: AWS2P
Wecare_ITA
