Solved Installation ISO is incorrect
mls.nicolas
Gold Partner
I was trying to install the 3CX SBC on debian and downloaded it from the partner portal https://downloads-global.3cx.com/downloads/debian12iso/debian-amd64-netinst-3cx.iso
Tried also the link from the public KB, it's the same : https://www.3cx.com/docs/installation-sbc/
After creating the VM and begining the installation, it looks like the ISO is incorrect and is missing every 3CX steps, as well as network configuration. Also, it's a pure CLI driven wizard, and not a graphical TUI.
Can anyone else try it ?
Thanks !
Reactions: TheodorosG_3CX
@TheodorosG_3CX @Alphabetic
That's exactly what I did. I'm not looking for the download links guys.
I used this ISO, but the installation wizard is broken.
I booted up with the ISO no problem..
at what point is it not GUI?
What are you trying to install the ISO on?
There is no issue with the ISO, double checked without any problem.
Can you share a screenshot on the failure you experience?
Good to know, thank you @Alphabetic @TheodorosG_3CX
I'm on a proxmos 9.1.9 VM.
I attached the same ISO on another new VM as I did twice before opening the thread, and now the usual 3CX/Debian wizard is displayed.
I'll go through the wizard to be sure, but it looks like it was a me issue :)
Thanks for the double check guys
Reactions: mls.nicolas
All good, my SBC is up now.
maybe a solar flare was the issue
mazet
