Installing Albania & Kosovo local number
shalafinesa
How do I have to add my local business numbers in the 3cx. I installed and did all the configuration now I just need to add my employees and the local numbers in order clients to call me
Reactions: VasilisV_3CX
To get a number you'll basically need a SIP Trunk from a SIP Provider. We highly recommend using one of the 3CX Supported SIP Providers which have been tested with 3CX and will hence, not only guarantee a trouble-free experience but also be much easier to configure and use: https://www.3cx.com/partners/sip-trunks/
As @ConceptsWeb mentioned, I do also recommend checking our training material for more info if needed.
You can find more info for SIP Trunks and their configuration below. You should also fine information for allowing incoming calls: https://www.3cx.com/3cxacademy/videos/basic/configuring-voip-providers/
For Outgoing calls you will need to create Outbound Rules. For more information I recommend checking the following course: https://www.3cx.com/3cxacademy/videos/advanced/configuring-outbound-routing/
Let us know if you need any more help or clarification.
megalmazan
