Installing Update 6 RC2
Stephen H
Greetings,
I am currently at Version 20.0 Update 5 (Build 551 Release) and only see New 20.0 Update 6 Alpha in my updates pane. Do i need to install this Alpha version to then be able to be offered V6 RC2 installer?
Many thanks
You will need to update through all the versions available for U6 until you reach the RC2 beta. Alternatively, you can wait for the final release of U6 to update directly to it.
circusduck
