Installing windows client in RDS
ipt_dude
We are running 13 RDS terminal servers. Our telephony folks are migrating us to 3cx. I see the windows client does not install under "program files" or ""program data" so it will not allow any user logging into the server to access the application. I only see the application installing to the local app data dir. Is that the case and there isnt an installed that will allow any user to access it? Based on the information that it has to be provisioned each time im guessing that is the case and its not really designed for a terminal server environment.
Install location (only installs in app data on local profile, does not install system wide to allow ALL users access”
