Integrating 3CX with odoo ERP/CRM
vincent Kavila
I needed to integrate odoo ERP/CRM with 3CX, is it possible?
Any one with any KBA?
We did it, using a custom proxy script and the XMLRPC API.
Some people did third-party modules on the Marketplace but I wouldn't recommend them as you have no way of knowing how long it will be supported.
Reactions: PanagiotisL_3CX
Hi @vincent Kavila , I'm Pierre Locus, representing Nalios (an Odoo partner).
I did the full integration with the CRM Template with an Odoo module - in case you don't want to depend on third parties :)
You can find it in the Odoo Store: https://apps.odoo.com/apps/modules/16.0/nalios_3cx_full/
It's for Odoo 16 but can be downgraded in case of need to older versions.
If you need anything else or more details or a demo, don't hesitate pinging me at [email protected] !
Regards
  • Haha
Reactions: MiraG_3CX
What is your advise?
Is this something you would be willing to share? (For internal use). The third party apps is something that worries me as well.
We can discuss for sure.
VOIPEric
