- Joined
- Nov 12, 2023
- Messages
- 2
- Reaction score
- 1
Hello
Using the 3CX CRM Integration Wizard, we created a template for Business Central (Online).
After adding the template to 3CX and entering our ClientID and ClientSecret, I can click on the Authorize button.
I'm then presented with a login to Microsoft 365. After logging in, I'm returned to https://xxxxx.3cx.ca/api/oauth2crm with an error:
I'm able to authorize and access the Business Central API's in Postman without issue.
Is there a template available for Business Central?
Thanks in advance.
Code:
Error occured while accessing CRM. Please check log provided.
Started OAuthGetRefreshToken
Request text: https://login.microsoftonline.com/xxxxx/oauth2/v2.0/token
Request form value code set to xxxxx
Request form value grant_type set to authorization_code
Request form value client_id set to xxxxx
Request form value client_secret set to xxxxx
Request form value redirect_uri set to https://xxxxx.3cx.ca/api/oauth2crm
Request form value state set to xxxxx
Request form value scope set to https://api.businesscentral.dynamics.com/.default
Response text: {"token_type":"Bearer","scope":"https://api.businesscentral.dynamics.com/Financials.ReadWrite.All https://api.businesscentral.dynamics.com/user_impersonation https://api.businesscentral.dynamics.com/.default","expires_in":4904,"ext_expires_in":4904,"access_token":"xxxxx"}
Response finished
Finished OAuthGetRefreshToken
System.Exception: CRM call result is empty or null
at ManagementConsoleJS.Controllers.OAuth2CrmController.OAuth(String state, CrmProcessorFactoryDelegate crmProcessorFactory, IMemoryCache cache)
Thanks in advance.
