Interactions With Callers
gb
Is there currently any way in 3CX that after you receive a call and have been talking,
to have the caller listen to a pre-recorded message and then automatically come back so you can continue talking again?
You say that once the call is hung up with an agent, the caller is redirected to a pre-recorded message and then redirected to another agent (or the same one)?
Normally you could do this with CFD.
If you don't need it to come back, you can use an IVR.
With CFD you cant do this on a hung up, the agent will have to tranfert it on the CFD (extention number).
He never said it was on hangup, it is for prerecorded message during a call, so CFD would work just fine.
I just gave that point for a global scenario.
mazet
