Intercom/auto answer doesn't work
dc082782
SMB User
When cIick the intercom button on a contact via the web portal, it just rings the user's desk phone. I even tried to setup
Paging but that isnt working either. Help is greatly appreciated thanks ʕ•ᴥ•ʔ
Yes the screenshot is attached. I have a polycom soundpoint 335 and a Polycom vvx 101. I contacted poly support and they said both support paging and intercom.
All 3 phones are on SBC. Everything works fine. Except paging option and intercom.
Does intercom "phone to phone" work?
Intercom is not possible on SMB and Free editions (if you try it, it will be just a normal call).
It is only available on Pro and Enterprise editions.
Why Is It listed an an option then? That's interesting.
Intercom with auto answer ONLY on the intercom calls does not work even on the paid pro versions..
There are published documents on how to make this work.. When you configure the paging code and you add the extension the call is sent just as a regular call..
It doesn't even allow me to set a paging code anywhere. I wish 3cx would fix this. I can't create paging groups either.
cvanderzwan
