I’ve just tried that with the default template and that works fine. I was using a custom template to have distinctive ring tone for external calls. With those changes it’s obviously messed up the intercom functionality. I’ll compare the two templates to see if there’s something obvious that could cause problemsHi Paul
The VVX411 can intercom normally when setup correctly. Please check the following conditions have been met:
Once the above has been met, you can dial your paging code + VVX411 extension, and the phone will ring and automatically answer.
- You are using an updated version of 3CX
- You are using default templates (not custom)
- The phone is using the latest supported firmware (6.3.0.14929) and has been factory reset
- The phone has been automatically provisioned exactly as per our guide
- Your extension and the VVX411 are members under the same user Group
- Your extension (the one making the call) has the right "Can Intercom" under the same Group that the VVX411 is a member of
- You have defined a Paging code under Settings > Dial Codes (must NOT overlap with other codes)
So for example in my PBX I have the paging code *11 and the VVX411 is extension 250.
I now dial *11250 and the VVX automatically answers and we have an intercom call as expected.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
