Intermittent Call Drop on Answer
ChrisNSG
Hello everyone,
I have an issue with inbound calls intermittently disconnecting when answered. Here's information about the system:
  • 3CX Version, Standard Annual 18.0 (Build 912)
  • Server OS, Debian 10
  • Is the 3CX Server Hosted and where? Hosted in Amazon AWS EC2 instance
  • IP Phone Make/Model/Firmware version, Yealink W60B 77.85.0.25 with Yealink W56H handsets
  • Provisioning Method: SBC
  • Trunk Provider or VoIP Gateway Make/Model, Flowroute
  • Has the Firewall Checker passed: Yes
  • Are custom Phone Templates being used: No
When answering a call, the phone will display "Media Error" and the call will drop. This happens to only a few calls a day, and the caller will call right back in and can be answered. I have not been able to find a pattern for the disconnected calls. This issue has been happening for a long time now, so I'm not sure when it started. Yesterday I turned verbose logging on and ran packet captures for 15 minutes at a time till the issue happened. Attached is the activity log from that time/call, I've scrubbed it of sensitive information, so phone numbers and IP's are changed but still readable. I'm hoping someone will be able to tell me what caused the call to hang up. I'm not sure I'm reading the packet capture correctly but it looks like the hang up is coming from the 3CX system local host 127.0.0.1
Thank you!
nicolamusci
