Solved Internal SSL certificate
drsam.theme
Need help. For the web client to work locally, a different domain is used than the outside. Generated an SSL certificate for this domain, where to put it so that it works on the internal web client. The system is on Linux.
Thank you!
This is not the way to do it.
You will need to create an internal DNS entry for your 3cx.eu domain that you are using, and point it to the internal IP address of the server.
You will NOT install nother certificate on 3CX.
https://www.3cx.com/docs/creating-fqdn-split-dns/
Of course!
How could I not have thought of it myself?) Super! I added the 3cx.eu zone to my local DNS, added the A record of the pbx server in it and everything worked as it should. The SSL certificate was accepted. Thank you very much!
