Investigating a Dropped Call Using Log Reader
spongebob
Dear All
I was on a call today that suddenly dropped. I wanted to see if I could investigate the cause using the 3CX Log Reader. I noted down the time, duration and destination of the call to help me look this up.
When I downloaded the support file earlier today (a couple hours after my dropped call), it only contains about 12 lines and none of them seemed very relevant. We've been using our phone system since March so I was surprised to not see loads of lines in here. I did happen to notice in the Event Log the following message which occurred less than 1 minute after my dropped call:
3CX logs and temporary files were deleted to conserve disk space.​
I've just carried out a system update because I noticed there was one waiting and thought I'd try downloading the logs again. This time, I have tonnes of lines in the log but all from the last 5 minutes and I think are related to update just carried out. There aren't any lines for the rest of the day or for previous days despite our phone system being used quite heavily.
Is it possible we haven't configured logging correctly and they are being lost or am I trying to access them incorrectly? Do you think it was pure coincidence that the logs and temporary files were deleted less than a minute after my dropped call or could this be related?
Thank you so much for your help.
Dan
For the most information you would have to put your 3CX logging in to Verbose mode. It is likely yours is currently Low or Off.
You will also probably have your logs set to re-cycle every x days.
A Wireshark capture would tell you what happened if you're able to replicate the problem.
DrunkeMeister
